Switch to full style
Post a reply
SOLD: Dual P-Mags and EI Commander
Sat May 06, 2017 9:24 am
2 P-Mags with Lycoming mag gears (1 ver 40 / 1 ver 37), EI Commander with connector, MAP sensor with connector, 2 mag gaskets, vacuum restrictor, vacuum Y with drilled rivet, 20 P-Mag plug wires, P-Mag manual, EI Commander Manual, 2 extra coil connectors, 9 misc spark plugs. Less than a few hundred hours of use. Everything in great condition ready to go. I'm now testing another ignition system. $3K + shipping. This is the whole package, I will not split it.
Re: FS: Dual P-Mags and EI Commander
Thu May 11, 2017 12:04 pm
Randy, I am interested in your P-Mags. What were they installed on and why did you remove?
Thanks
Jim
Thu May 11, 2017 1:59 pm
Hi Jim, they were installed in my Lancair 360, I flew them for a few hundred hours and now I'm testing dual ElectroAir's to see how those perform. I sometimes get products to test or use. ECI, Vertical Power, MGL, ElectroAir, etc.
This is the complete system with the EI Commander to monitor and program the pmags.
Randy
Sat May 13, 2017 8:55 am
Randy, can you send me a phone nr so we call speak. I have some questions about P-mag.
Jim
Sun May 14, 2017 12:07 am
No longer available.
Post a reply
