FOR SALE: Complete Avidyne Entegra Suite
Postby Paul Miller » Fri Oct 03, 2014 11:20 am
These are certified units good for Cirrus, Piper and other applications. Avidyne permits additional factory warranty although I have not needed it for years.
I have the MFD5000 and the EXP 5000. I also have a new Moritz DAU from Avidyne and the installed magnetometer which sits in the tail area. It all works perfectly but is no longer supported for the Lancair Legacy.
With this setup you can inexpensively upgrade steam gauge Cirrus, use for a tradeup credit with Avidyne and install with existing STCs in other aircraft like Pipers, for example.
My goal is to change out to a experimental avionics like Garmin or AFS, for example.
If anyone has any interest, these units would be immediately available.
