by Paul Miller » Tue Jun 27, 2017 4:09 pm
I have three more GTX-330ES panel mount transponders upgraded by Garmin for ADS-B out. They can be sold outright with tray and connector and hooked to your WAAS position source.
IF you are in need of flying with a transponder and just need the upgrade then talk to me about swapping your excellent-shape 330-non-ES and send it to me when you get the ES installed.
The outright is $2450 and contact me for exchanging. These are from Garmin with 8130s, Garmin warranty and tray and connector. They are good for any aircraft as a standalone "out" solution. In can be via a GDL-39 or many other "in" solutions.
You will also be eligible for your FAA rebate of $500 and these units are eligible equipment as is just the upgrade swap.
I have three available.
What do you need for your Lancair Build or maintenance? Talk
here.
by Paul Miller » Mon Jul 17, 2017 9:57 pm
Wow, the rebate deadline must be working, 2 of these units are sold over the weekend. I'm getting two more to convert, maybe someone has one not needed they wish to sell...contact me.
here.
