FS: Instruments
FS: Instruments
Postby Jack Dekkinga » Thu Oct 12, 2017 3:24 pm
Harvested from -4P Panel Upgrade
GRT EIS 6000 with warning light, cyl & egt wiring $450
S-Tec Directional Gyro Model 4000-6, PN 1U262-006-45 $1000
Turn Coordinator Mid Continent PN 1394T100-7ZP Lancair faceplate TSO'd $250
VSI United Inst. PN 7040 Lancair faceplate $150
Altimeter United Inst -1000/35,000' PN 5934PAD-3 TSO'd Lancair faceplate $385
Airspeed Indicator United Inst PN 8140 TSO'd Lancair faceplate $400
Rocker panel with rocker switches #12 incl ALT/BATT, AVIONICS MASTER, PITOT HEAT, NAV LIGHTS, LANDING LIGHT, STROBE LIGHTS, blank, DIMMERS, DOOR SEAL, CABIN FAN, LOW BOOST, HIGH BOOST....$250
Ammeter/Voltmeter Electronics International STC'd Model VA-1A 50 $250
TruTrak Vizion 385 Autopilot with auto level button, 2 basic servos and mounting brackets $1500
Gear Indicator Lights....set of 4 (3green/1yellow) $100
Voltage Converters Princeton Electronics, CP10A Qty. 2 $75 ea.
Circuit Breakers 7277 series 2-3-5-7.5-10 Amps $10 each
Circuit Breaker Potter & Brumfield 50Amp $30
Pictures on request....dekky111@gmail.com
That's all for now....
Jack Dekkinga
