WTS: Lancair IVP Kit
Postby Danny Miller » Fri Mar 09, 2018 10:43 am
Posting for a friend, more pix available. Partially built, will take best reasonable offer. Wings were closed with fuel tanks ready for fuel at the Lancair factory in Redmond, OR in 1999 with owner’s assistance. Lancair precision jigs were used to mount the wings on the fuselage.
The IVP kit contains component inventory sheets, construction manuals, engineering drawings and invoices, basic air frame, less power plant, avionics, instruments, paint, and upholstery. Owners purchased a second set of bolts, screws and various construction parts. The wiring, plumbing and fuel system components are complete.
New builder will have to replace the Jeffco epoxy and hardener (used to bond the fuselage panels) that have well exceeded their shelf life and would not provide structurally sound assemblies. Rubber components will require inspection for serviceability before use but the kit has remained in a dry environment since delivery to Warrenton, VA in July 1999 so most, if not all, such components should be serviceable.
Contact Rick or Peggy Koehnke for more info at 540-229-7713, 540-229-0505, pegdoyle17 at gmail dot com or Rkkoehnke at gmail dot com.
:anyone:
Fuselage in rotisserie
Cradled wings
Numerous parts
Work bench & books
Danny
LNC2-II
Danny Miller
Users browsing this forum: No registered users and 102 guests
