by Jose Santos » Fri Nov 10, 2017 9:37 am
Hello;
My project is stuck in not being able to find key components anywhere. My immediate needs are:
hydraulic kit for inner main doors (cylinders, springs, brackets)
hydraulic stainless steel hoses for main and nose gear
over center linkage hardware nose gear
sequential valves for main gears
header tank, all fittings, hardware
main gear hydraulic shocks
Thanks.
Jose Santos
Jose Santos
by Jose Santos » Fri Nov 10, 2017 3:17 pm
Risse Racing has been (sadly) mentioned several times in our forum due to less than ideal customer satisfaction...
Jose Santos
by Paul Miller » Fri Nov 10, 2017 3:29 pm
But our good friend Justin from Lancair and recently Evolution is now at Risse, I think those issues are going to be behind us and he said as much in a recent posting when he joined. You could PM or ask directly in email from his link online here.
What do you need for your Lancair Build or maintenance? Talk
here.
by Eric Miller » Sat Nov 11, 2017 9:20 am
I PM'd Justin a week or so ago, on a shock related issue, and he addressed it quickly, hardware was shipped immediately.
Eric
N9BF '95 IO-320 Mk I #771
Eric Miller
by Christian Meier » Sun Nov 12, 2017 3:15 am
Jose
Lancair should have those gear parts on stock.
For the header tank, make one out of foam and laminate with epoxy/glass. It will be better than the original one out of polyester!
You will find pictures for the fuel tank on my site:
www.lancair.atChristian
Christian Meier
Users browsing this forum: No registered users and 9 guests
